StartOS 0.4.0-beta.9 Connect Sparrow to Bitcoin node
I’m trying to connect Sparrow to the Bitcoin node hosted on StartOS 0.4.0-beta.9. I think the correct interface to use is RPC Interface. I did the “Generate RPC User Credentials” already and restarted the service. If I use that IP and port, I just get the following error:
Cannot invoke “com.github.arteam.simplejsonrpc.core.domain.ErrorMessage.toString()” because “parameter1” is null
Is the RPC Interface the correct port to use? Is there anything else I need to do?
Got this figured out. The RPC Interface does have the correct IP and port combination. However, Sparrow defaults to “http” and this can’t be changed in the UI. I was able to find the Sparrow config file (%APPDATA%\Sparrow\config) and simply update the URL to “https”
