StartOS freezing
Hi,
My StartOS server is freezing at least once per day.
When server freezes, it doesn’t shut down and ethernet lights are blinking. Also, I have noticed that it isn’t listed in LAN devices list when checking on the router. Of course, I can’t reach server through browser or SSH (ssh start9@192.168.1.100
ssh: connect to host 192.168.1.100 port 22: No route to host
I have tried with connected monitor, mouse and keyboard, but screen is black. When restarted, everything works normal for a day or less.
As this was happening every day, yesterday I have opened SSH connection on my laptop and in terminal run sudo journalctl -xefa. As you can notice the last line in log is nextcloud.
I am not sure is it the nextcloud service a reason for server failure so will appreciate is someone can check the log and see it something else.
Feb 28 12:55:01 ironic-surface CRON[3432648]: pam_unix(cron:session): session closed for user root
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: Unhandled Error
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: Traceback (most recent call last):
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/python/log.py”, line 96, in callWithLogger
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: return callWithContext({“system”: lp}, func, *args, **kw)
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/python/log.py”, line 80, in callWithContext
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: return context.call({ILogContext: newCtx}, func, *args, **kw)
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/python/context.py”, line 117, in callWithContext
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: return self.currentContext().callWithContext(ctx, func, *args, **kw)
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/python/context.py”, line 82, in callWithContext
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: return func(*args, **kw)
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: — —
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/internet/posixbase.py”, line 482, in _doReadOrWrite
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: why = selectable.doRead()
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/internet/tcp.py”, line 248, in doRead
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: return self._dataReceived(data)
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/internet/tcp.py”, line 253, in _dataReceived
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: rval = self.protocol.dataReceived(data)
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/internet/endpoints.py”, line 151, in dataReceived
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: return self._wrappedProtocol.dataReceived(data)
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/txtorcon/socks.py”, line 529, in dataReceived
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: self._machine.feed_data(data)
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/txtorcon/socks.py”, line 136, in feed_data
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: self.got_data()
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/automat/_methodical.py”, line 284, in got_data
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: value = output(oself, *a, **k)
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/automat/_methodical.py”, line 322, in call
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: return self.method(oself, *args, **kwargs)
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/txtorcon/socks.py”, line 311, in _relay_data
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: self._sender.dataReceived(d)
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/protocols/tls.py”, line 324, in dataReceived
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: self._checkHandshakeStatus()
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/protocols/tls.py”, line 251, in _checkHandshakeStatus
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: self._tlsShutdownFinished(Failure())
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/protocols/tls.py”, line 377, in _tlsShutdownFinished
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: if _representsEOF(reason.value):
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/protocols/tls.py”, line 121, in _representsEOF
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: errorQueue = exceptionObject.args[0]
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: builtins.IndexError: tuple index out of range
Feb 28 12:55:02 ironic-surface jam.embassy[76886]: 2025-02-28 12:55:01,410 [INFO] Lost IRC connection to: darkirc6tqgpnwd3blln3yfv5ckl47eg7llfxkmtovrv7c7iwohhb6ad.onion . Should reconnect automatically soon.
Feb 28 12:55:04 ironic-surface startd[874]: 2025-02-28T12:55:04.190952Z DEBUG run_main:check: startos::manager::health: Checking health of lnd
Feb 28 12:55:04 ironic-surface podman[3432662]: 2025-02-28 12:55:04.249911471 +0000 UTC m=+0.052980541 container exec 6c96e90eb56be2ea0097693d4ee5aa2ee15e04304da05aa36a4e73625e831177 (image=docker.io/start9/lnd/main:0.18.5, name=lnd.embassy)
Feb 28 12:55:04 ironic-surface podman[3432662]: 2025-02-28 12:55:04.26093174 +0000 UTC m=+0.064000800 container exec_died 6c96e90eb56be2ea0097693d4ee5aa2ee15e04304da05aa36a4e73625e831177 (image=docker.io/start9/lnd/main:0.18.5, name=lnd.embassy)
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: Unhandled Error
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: Traceback (most recent call last):
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/python/log.py”, line 96, in callWithLogger
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: return callWithContext({“system”: lp}, func, *args, **kw)
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/python/log.py”, line 80, in callWithContext
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: return context.call({ILogContext: newCtx}, func, *args, **kw)
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/python/context.py”, line 117, in callWithContext
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: return self.currentContext().callWithContext(ctx, func, *args, **kw)
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/python/context.py”, line 82, in callWithContext
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: return func(*args, **kw)
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: — —
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/internet/posixbase.py”, line 482, in _doReadOrWrite
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: why = selectable.doRead()
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/internet/tcp.py”, line 248, in doRead
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: return self._dataReceived(data)
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/internet/tcp.py”, line 253, in _dataReceived
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: rval = self.protocol.dataReceived(data)
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/internet/endpoints.py”, line 151, in dataReceived
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: return self._wrappedProtocol.dataReceived(data)
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/txtorcon/socks.py”, line 529, in dataReceived
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: self._machine.feed_data(data)
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/txtorcon/socks.py”, line 136, in feed_data
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: self.got_data()
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/automat/_methodical.py”, line 284, in got_data
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: value = output(oself, *a, **k)
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/automat/_methodical.py”, line 322, in call
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: return self.method(oself, *args, **kwargs)
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/txtorcon/socks.py”, line 311, in _relay_data
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: self._sender.dataReceived(d)
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/protocols/tls.py”, line 324, in dataReceived
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: self._checkHandshakeStatus()
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/protocols/tls.py”, line 251, in _checkHandshakeStatus
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: self._tlsShutdownFinished(Failure())
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/protocols/tls.py”, line 377, in _tlsShutdownFinished
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: if _representsEOF(reason.value):
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/protocols/tls.py”, line 121, in _representsEOF
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: errorQueue = exceptionObject.args[0]
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: builtins.IndexError: tuple index out of range
Feb 28 12:55:04 ironic-surface jam.embassy[76886]: 2025-02-28 12:55:03,679 [INFO] Lost IRC connection to: darkirc6tqgpnwd3blln3yfv5ckl47eg7llfxkmtovrv7c7iwohhb6ad.onion . Should reconnect automatically soon.
Feb 28 12:55:04 ironic-surface startd[874]: 2025-02-28T12:55:04.729526Z DEBUG run_main:check: startos::manager::health: Checking health of c-lightning
Feb 28 12:55:04 ironic-surface podman[3432706]: 2025-02-28 12:55:04.79444114 +0000 UTC m=+0.056761423 container exec dfccc6623478eddee00b10949b66051e1aaadefd30e6bdfd287d1c9899bb4f89 (image=docker.io/start9/c-lightning/main:24.11.1.1, name=c-lightning.embassy)
Feb 28 12:55:04 ironic-surface podman[3432708]: 2025-02-28 12:55:04.832021481 +0000 UTC m=+0.094473665 container exec dfccc6623478eddee00b10949b66051e1aaadefd30e6bdfd287d1c9899bb4f89 (image=docker.io/start9/c-lightning/main:24.11.1.1, name=c-lightning.embassy)
Feb 28 12:55:04 ironic-surface podman[3432706]: 2025-02-28 12:55:04.835098711 +0000 UTC m=+0.097419014 container exec_died dfccc6623478eddee00b10949b66051e1aaadefd30e6bdfd287d1c9899bb4f89 (image=docker.io/start9/c-lightning/main:24.11.1.1, name=c-lightning.embassy)
Feb 28 12:55:04 ironic-surface podman[3432708]: 2025-02-28 12:55:04.848448304 +0000 UTC m=+0.110900467 container exec_died dfccc6623478eddee00b10949b66051e1aaadefd30e6bdfd287d1c9899bb4f89 (image=docker.io/start9/c-lightning/main:24.11.1.1, name=c-lightning.embassy)
Feb 28 12:55:04 ironic-surface podman[3432707]: 2025-02-28 12:55:04.881945519 +0000 UTC m=+0.144469949 container exec dfccc6623478eddee00b10949b66051e1aaadefd30e6bdfd287d1c9899bb4f89 (image=docker.io/start9/c-lightning/main:24.11.1.1, name=c-lightning.embassy)
Feb 28 12:55:04 ironic-surface podman[3432707]: 2025-02-28 12:55:04.906361889 +0000 UTC m=+0.168886319 container exec_died dfccc6623478eddee00b10949b66051e1aaadefd30e6bdfd287d1c9899bb4f89 (image=docker.io/start9/c-lightning/main:24.11.1.1, name=c-lightning.embassy)
Feb 28 12:55:06 ironic-surface startd[874]: 2025-02-28T12:55:06.517873Z DEBUG run_main:check: startos::manager::health: Checking health of simplex
Feb 28 12:55:06 ironic-surface podman[3432870]: 2025-02-28 12:55:06.573467974 +0000 UTC m=+0.050254004 container exec a48282460d60cf8a2624f443a2c62b328b7037839f14f9f6fd1460a62163add7 (image=docker.io/start9/simplex/main:6.1.3.1, name=simplex.embassy, org.opencontainers.image.ref.name=ubuntu, org.opencontainers.image.version=22.04)
Feb 28 12:55:06 ironic-surface podman[3432896]: 2025-02-28 12:55:06.636591711 +0000 UTC m=+0.056454561 container exec_died a48282460d60cf8a2624f443a2c62b328b7037839f14f9f6fd1460a62163add7 (image=docker.io/start9/simplex/main:6.1.3.1, name=simplex.embassy, org.opencontainers.image.ref.name=ubuntu, org.opencontainers.image.version=22.04)
Feb 28 12:55:06 ironic-surface podman[3432870]: 2025-02-28 12:55:06.641442511 +0000 UTC m=+0.118228650 container exec_died a48282460d60cf8a2624f443a2c62b328b7037839f14f9f6fd1460a62163add7 (image=docker.io/start9/simplex/main:6.1.3.1, name=simplex.embassy, org.opencontainers.image.ref.name=ubuntu, org.opencontainers.image.version=22.04)
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: Unhandled Error
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: Traceback (most recent call last):
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/python/log.py”, line 96, in callWithLogger
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: return callWithContext({“system”: lp}, func, *args, **kw)
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/python/log.py”, line 80, in callWithContext
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: return context.call({ILogContext: newCtx}, func, *args, **kw)
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/python/context.py”, line 117, in callWithContext
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: return self.currentContext().callWithContext(ctx, func, *args, **kw)
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/python/context.py”, line 82, in callWithContext
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: return func(*args, **kw)
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: — —
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/internet/posixbase.py”, line 482, in _doReadOrWrite
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: why = selectable.doRead()
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/internet/tcp.py”, line 248, in doRead
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: return self._dataReceived(data)
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/internet/tcp.py”, line 253, in _dataReceived
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: rval = self.protocol.dataReceived(data)
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/internet/endpoints.py”, line 151, in dataReceived
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: return self._wrappedProtocol.dataReceived(data)
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/txtorcon/socks.py”, line 529, in dataReceived
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: self._machine.feed_data(data)
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/txtorcon/socks.py”, line 136, in feed_data
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: self.got_data()
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/automat/_methodical.py”, line 284, in got_data
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: value = output(oself, *a, **k)
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/automat/_methodical.py”, line 322, in call
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: return self.method(oself, *args, **kwargs)
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/txtorcon/socks.py”, line 311, in _relay_data
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: self._sender.dataReceived(d)
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/protocols/tls.py”, line 324, in dataReceived
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: self._checkHandshakeStatus()
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/protocols/tls.py”, line 251, in _checkHandshakeStatus
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: self._tlsShutdownFinished(Failure())
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/protocols/tls.py”, line 377, in _tlsShutdownFinished
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: if _representsEOF(reason.value):
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: File “/usr/local/lib/python3.9/dist-packages/twisted/protocols/tls.py”, line 121, in _representsEOF
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: errorQueue = exceptionObject.args[0]
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: builtins.IndexError: tuple index out of range
Feb 28 12:55:07 ironic-surface jam.embassy[76886]: 2025-02-28 12:55:06,322 [INFO] Lost IRC connection to: darkirc6tqgpnwd3blln3yfv5ckl47eg7llfxkmtovrv7c7iwohhb6ad.onion . Should reconnect automatically soon.
Feb 28 12:55:08 ironic-surface startd[874]: 2025-02-28T12:55:08.780353Z DEBUG run_main:check: startos::manager::health: Checking health of nextcloud
Feb 28 12:55:08 ironic-surface podman[3432915]: 2025-02-28 12:55:08.838309597 +0000 UTC m=+0.052030920 container exec 082b57a0917f5fd4c579a286df1bf122852cb3434d4e74a4a2860d4b066a9e0b (image=docker.io/start9/nextcloud/main:27.1.7, name=nextcloud.embassy)
Feb 28 12:55:08 ironic-surface nextcloud.embassy[4480]: 127.0.0.1 - 28/Feb/2025:12:55:08 +0000 “GET /index.php” 200
Feb 28 12:55:08 ironic-surface podman[3432940]: 2025-02-28 12:55:08.925439065 +0000 UTC m=+0.045336547 container exec_died 082b57a0917f5fd4c579a286df1bf122852cb3434d4e74a4a2860d4b066a9e0b (image=docker.io/start9/nextcloud/main:27.1.7, name=nextcloud.embassy)
Feb 28 12:55:08 ironic-surface podman[3432915]: 2025-02-28 12:55:08.930193904 +0000 UTC m=+0.143915207 container exec_died 082b57a0917f5fd4c579a286df1bf122852cb3434d4e74a4a2860d4b066a9e0b (image=docker.io/start9/nextcloud/main:27.1.7, name=nextcloud.embassy)
Typically things like this are a result of hardware. Whether this is a driver issue, or something wrong with the SSD or RAM can depend. But it would full logs to try and find a pattern, specifically logs that cover the moment where things went wrong.
I take it this is DIY hardware and not something you bought from Start9?
It’s very unlikely for a service inside a docker container to affect the whole OS. But if for some reason you were sure the issue was Nextcloud and this happens every day… simply stop Nextcloud to confirm your hypothesis.
Hi,
thanks for feedback.
StartOS is installed on the mini PC (GMKTEC M5 PLUS, 5825U).
I would like to mention that for last 3 months I was running startos in Virtualbox (MX Linux) on that minipc. I am currently using Raspiblitz but as some of my friends are interested to run their nodes I decided to get familiar with StartOS because Raspiblitz is all terminal and I don’t see that they will use it easily.
This Monday I have decided to install StartOS on bare metal and problems started. This is the main reason why I doubt that hardware is a problem, but who knows. I don’t know is it possible that there is some conflict because I have 2 mini pc’s in the same router, one with Raspiblitz and one with StartOs?
I notice in that there is same problem with another user: Backup of log files - #3 by Dtex
So on this machine there was no problem running StartOS in the VM, but running it on the bare metal it’s seemingly unstable? If that’s the case, I’d come to the conclusion that there’s a component in this machine that doesn’t have a driver in StartOS. I assume you’re already using the non-free ISO, but if even that doesn’t work, you may want to wait and try with the next version of StartOS with a newer linux kernel.
Thanks. I will wait then, but also trying some turn off on testing :slight_smile:
Just one last question because something strange now happened.
I have unplugged mini pc from router and bring it closer to my second PC so I can play with it. Then tried to login at Reserved IP Address 192.168.1.100 to MAC address 84-47-09-44-ED-A4, but unsuccessfully.
The router have changed StartOS MAC and IP address of the mini PC:
Device name
start-001
MAC address
84-47-09-44-ED-A3 (before: 84-47-09-44-ED-A4)
IPv4 adddress
192.168.1.9
Is this normal?
Also, WIFI is not working(RPC ERROR: WiFi Internal Error No WiFi interface available)
90% of all issue with not being able to contact the server or the server “freezing” have nothing to do with the server and are instead something to do with network setup or DIY hardware – something we can’t possibly help you with. Looks like your hardware has some kind of random MAC addressing that also means the router treats it as a new device each time. But as I say, I’m not sure and I can’t be sure what’s normal with your hardware.
