Hi all,
I run Core Lightning on StartOS with the watchtower client plugin (rust-teos), and I also run a tower myself. After hitting a bug in the client recently, I looked at the state of the project. I’d like to share what I found and ask how others see it.
What happened
On 2026-11-21 the watchtower client panicked twice on my routing node. A tower accepted the same appointment twice, the plugin’s database insert failed on a unique constraint, and the unwrap() happened while a mutex was held. The mutex got poisoned, and every later hook call failed until CLN was restarted. During that time the node had no watchtower coverage. I reported it upstream (talaia-labs/rust-teos#282) with a fix and tests (#283). Start9 merged the fix as a patch into the CLN package, so it ships with the next CLN release. Thanks to the Start9 team for picking it up so quickly.
State of rust-teos upstream
- Last commit: October 2025. Last release: v0.2.0, February 2023.
- 23 open pull requests, none merged in the last 12 months.
- The toolchain is pinned to Rust 1.81. Current CLN Rust crates need Rust 1.85 or later, so the plugin can’t easily pick up newer CLN libraries.
- Other known issues are open too, e.g. #239:'t atomic.
- Side note: my client database had grown to 908 MB, 75 % of it free pages. A VACUUM brought it down to 224 MB.
- In practice, Start9 is now the one keeping it working, by carrying patches.
Eclair for example
Eclair (ACINQ) has no watchtower client. It relies on uptime and a longer delay instead. By default it makes peers wait to-remote-delay-blocks = 720 (about 5 days) after a unilateral close before they can claim their funds, and it accepts up to 2016 blocks (about 2 weeks) for its own funds. A watchtower only matters if your node is offline longer than that window.
In CLN the equivalent setting is watchtime-blocks, and its default is 144 blocks, about 1 day. So if a CLN node is offline for more than a day, a peer could broadcast an old state, and only a watchtower would catch it. Raising watchtime-blocks (e.g. to 720 like Eclair, or 1008) for new channels gives you several days to recover from an outage, tower or not. Most implementations accept up **to 2016 blocks. The trade-**off is that peers wait longer after a force close.
My proposal / questions
- Keep it as it is
- Remove Watchtower from Start9 CLN (Feature request)
- interested in maintaining a fork together
1. Who here actually runs a tower, or uses the client with towers that are still reachable? Would you miss it?
2. If upstream stays silent, I think it would be reasonable to deprecate the watchtower in the CLN package and replace it with a longer default watchtime-blocks plus clear guidance (downtime alerts, longer delays). An unmaintained, security-relevant component that quietly stops working may be worse than none.
3. Alternatively: is anyone interested in maintaining a fork together (toolchain and dependency updates, the open fixes)?
Curious to hear other views, especially from people who run towers on CLN. I guess a good opportunity to play around with the Poll feature.
