HI
I’m stuck in a restart loop
I searched online and got this answer:
" Bitcoin Knots and Electrs have mismatched RPC credentials , a known bug in StartOS v0.3.5.1.
Re-save dependent services :
Go to Electrs → Config → Save (no changes needed). Do the same for RTL or any other service using Bitcoin. This forces them to re-fetch credentials.
If that fails, reindex Bitcoin Knots :
Go to BTC Knots → Menu → Actions → Re-index Blockchain . This fixes corruption from unexpected shutdowns.
That’s a bummer if I have to reindex bitcoin knots and wait at least a day to access my wallet linked to electrum.
any ideas? thanks
Try going to both services, one at a time, opening up the “config” menu and just click on “Save”.
That is the simplest / quickest solution.
But checking the service logs for errors is always the best course of action. If there is indeed signs of corruption, then you might have to try the “Re-index Blockchain” Action.
so it worked till today after reindexing all the block! 24hrs… and now it’s doing the restart again! can’t access my cold wallet from Tor… I had to disconnect in order to move on! anyone know what’s going on here? thanks
A System Rebuild, which won’t delete or change anything. Just rebuilds the containers.
You can find this option under System → Power → System Rebuild
Keep in mind that It may take up to 70 minutes to complete. During this time, you will lose all connectivity to your server, so just be patient and let the process finish and the server will come back online when it finishes.
Thanks Alvaro,
In the meantime what I did last nite is :
System/Experimental Features/Reset Tor/Wipe State (Before doing this I stopped both the Knots and Electrs
It seems to work since yesterday…
Will definitely try your suggestion if it goes back in a restart loop again!
I still want to find out why its doing this
