How do we enable start9 node with bitcoin core to accept and relay sub 1 sat/vbyte?
Hi there!
You change this value in Bitcoin config > mempool > Min Transaction Relay Fee.
Hi, it seems like this setting doesn’t exist for me?
Core 29.2.0~1
Under mempool i see:
persist mempool
max mempool size
mempool expiry
enable full rbf
permit bare msig
relay op return
max op return size
What’s weird is I do recall being able to tinker with this setting not long ago in start9, so something must have changed recently.
replying for an update
Hi there,
I’m running Bitcoin Knots and may have wrongly assumed it exposes this config options in Bitcoin Core as well. If not, you can create a feature request on GitHub to add it to the UI or switch to Knots.
It’s set by default to 0.1 sat/vByte since I think v29
Just curious why you want to do this?
