Supabase Integration
Hello everyone!
I’m a relatively new user to a Start9 server and I really love it so far, digging deeper into the feature set bit by bit.
Now I wondered if I could also host custom applications on my server, like Supabase. And if that’s not possible, how does the process of supporting more applications work?
Thanks in advance and best regards!
New software is packaged for StartOS specifically. With the introduction of the new packaging paradigm along with the next version of StartOS, things are changing.
If you’re a developer and you’d like to learn how to package for StartOS, you can join us at: https://matrix.to/#/#dev-service-packaging:matrix.start9labs.com
If not, and you’d like to simply suggest services for someone in the community to take up, take a look at: https://startos.fans
Thats awesome, thanks for the clear answer! :smiley:
I’ll check out the links
