ThunderHub Preferences/Settings not remembered at restart
I’ve found that the ThunderHub preferences are not saved through a restart of ThunderHub (eg, healthcheck pings). Is there any way to save settings and have them save across system restarts/restarts of ThunderHub?
The regular settings seem to be preserved across restarts for me, so perhaps this is limited to just Amboss settings? I don’t grant access to my data to Amboss for privacy reasons so I’m unable to test this properly. Perhaps you could verify this, and check whether you’re correctly signed in to Amboss from ThunderHub (and perhaps remove that connection and add it back again).
Perhaps, but there’s no real place to ‘log in’. You just go to Settings cog in the top right corner of any page and toggle the options under “Amboss”
Amboss is found here in the menu. I’m not sure how well those toggles work if you’re not connected to Amboss. This doesn’t appear to be an issue with StartOS.
