ToR not working on 0.3.5.1
Hi, I am still on 0.3.5.1 because JAM is not yet supported in 0.4.0.
since a few hours, JAM is not working and I get the following error from the ToR logs: “At least one protocol listed as required in the consensus is not supported by this version of Tor. You should upgrade. This version of Tor will not work as a client on the Tor network. The missing protocols are: Desc=3 Microdesc=3”.
Can I simply SSH into my Start9 and upgrade Tor to fix Jam? Any guide to do that?
I’m getting the same error on Sparrow. Before and after updating Sparrow to latest version.
Seems to have only started after updating Tor
StartOS 0.4.0.4
Tor 0.4.9.14:2
I am also having tor issues and I am running version 0.3.5.1.
Did something change with Tor protocol or servers recently?
I’m also having the same issue. Still on 0.3.5.1, tor stopped working. All services dependent on tor no longer connect.
Getting the same exact issue. Still on 0.3.5.1, Tor stopped working. All services dependent on Tor no longer connect including Sparrow.
I’m sure many here havent updated due to JAM not being supported in the latest version of Start 9, and possibly having fidelity bonds still locked in.
And now it looks like tor is fully down for 0.3.5.1? Hopefully help arrives soon, because all services dependent on tor are nonresponsive
Agreed… Tor is down for dependent services. What a flippin’ Cluster F… nightmare this is becoming.
Hmm just tested its also down for 0.4.0.3. What is going on
Ignore my addition to this thread. Sparrow update released today (256) fixed my issue
on my Start9 0.3.5.1, I’ve tried updating tor on my jam container following a procedure which seems to work for umbrel with similar issue:
  • ssh’d into my S9
  • sudo podman exec -it jam.embassy bash
    tor --version
    apt update
    apt install -y tor
    tor --version
    exit
    sudo podman restart jam.embassy
Tor version updates correctly but after a few seconds goes back to the old one. it seems the container is automatically recreated or something and goes back to default.
Any clues how I could persist the Tor update?
Same here, any thoughts on this issue S9 team???
Just wanted to post here that you can recover any and all funds, but you will need to spin up bitcoin core on a separate machine, along with any affected services, then patch in and update tor for each service. I tried updating tor inside start9, but the images are signed by start9 so the signatures failed verification.
The core issue is that TOR now requires
Desc=3 Microdesc=3”
So you have to update tor to connect.
So is there anything I can do to get my S9 back to work? Not worried about recovering funds. More interested in what can be done to fix the ToR issue.
I resolved the issue that I was having with the Tor versioning errors. I updated my S9 to 0.4.1 as I had no dependencies on Start9 0.3.5.1. After this upgrade it did not resolve the Tor issue “This version of Tor will not work as a client on the Tor network. The missing protocols are: Desc=3 Microdesc=3”.” UNTIL…
I upgraded Sparrow to 2.5.6. This was a key resolve from Sparrow to address this documented issue.
I’m posting here the solution for people who’s still running on Start9 0.3.5.1. It comes from H0mer from the official Start9 support team.
You were actually very close. Installing the newer Tor inside the Jam container does work. What undid it was podman restart jam.embassy, which rebuilds the container from the package image and throws away the change. If you restart only Jam’s internal services instead, the new Tor stays until the next time Jam or the server restarts.
The proper solution is to update to the latest StartOS 0.4. Tor on 0.3.5.1 can’t be repaired, while on 0.4 it runs as its own service on a current version, and your .onion addresses carry over. Guide: https://docs.start9.com/start-os/0.4.0.x/update-040.html
For Now quick fix for you would be to get Jam running temporarily with the commands below, then open it on its LAN address. Don’t restart the container, or it reverts.
Steps (Jam will only be reachable over its LAN address, since StartOS 0.3.5.1’s own Tor is also affected):
apt update && apt install -y tor
tor --version # should now say 0.4.9.x
dinitctl stop jmwalletd; dinitctl stop ob-watcher; dinitctl stop tor
dinitctl start tor && dinitctl start ob-watcher && dinitctl start jmwalletd
exit
Don’t restart the container afterwards. Give it a minute or two to bootstrap, then reload Jam on its LAN address. If Jam, StartOS or the server restarts, repeat the steps. Please send me the output if tor --version doesn’t show 0.4.9 or the backend still won’t start.
This is a stopgap, not a fix. The real fix is a rebuilt Jam package with a current Tor. Upstream hasn’t released one yet, and I’ve raised a rebuild of the StartOS 0.3 package with the team. I can’t promise a date.
On StartOS 0.4: updating alone won’t help Jam, because the converted Jam keeps the same old Tor. There is a new Jam V2 for 0.4 on Start9’s beta registry, but it runs on a new JoinMarket backend and is still beta, so I’d hold off until we’ve checked it with existing wallets and fidelity bonds.
Your funds and fidelity bonds are on-chain and safe. Keep your seed backed up, and don’t uninstall Jam.
My issue was also fixed when I downloaded the latest version of Sparrow directly from Download - Sparrow Wallet
