So finally got my embassy up and running and started the process of syncing Bitcoin Core yesterday morning.
This afternoon I realized id been stuck in the low 16% progress area all day. I checked the logs and noticed that every time it reached block height 413265 it stops and gives multiple errors and then restarts from block height 412202.
I am far from a coder and definitely fit into the everyday user Start9 intends to target. Any help would be greatly appreciated!
Blockquote
2023-03-21T16:53:41-04:00 2023-03-21T20:53:41Z LevelDB read failure: Corruption: block checksum mismatch: /root/.bitcoin/chainstate/042286.ldb
2023-03-21T16:53:41-04:00 2023-03-21T20:53:41Z Fatal LevelDB error: Corruption: block checksum mismatch: /root/.bitcoin/chainstate/042286.ldb
2023-03-21T16:53:41-04:00 Error: Error reading from database, shutting down.
2023-03-21T16:53:41-04:00 2023-03-21T20:53:41Z You can use -debug=leveldb to get more complete diagnostic messages
2023-03-21T16:53:41-04:00 2023-03-21T20:53:41Z Error: Error reading from database, shutting down.
2023-03-21T16:53:41-04:00 2023-03-21T20:53:41Z Error reading from database: Fatal LevelDB error: Corruption: block checksum mismatch: /root/.bitcoin/chainstate/042286.ldb
2023-03-21T16:53:43-04:00 PROCESS TERMINATED BY SIGABRT
2023-03-21T16:53:59-04:00 Error updating blockchain info: error: timeout on transient error: Could not connect to the server 127.0.0.1:8332
2023-03-21T16:53:59-04:00 Make sure the bitcoind server is running and that you are connecting to the correct RPC port.
