When I check for an update from version 3.5.1 my system says it’s up to date. Is the v4 available in Canada?
You can find instructions for installing 0.4.0 here:
Please read through the instructions in their entirety first. Then make sure you follow the instructions carefully. Improvising, or skipping steps can result in loss of data. It Bitcoin terms, data is money.
Ok. I was hoping it would be a little easier but i guess if i take my my time and follow the instructions i might learn something as well.
Thanks
We’re making it as easy as we can, but there is a lot going on there. The best way to minimize the complexity is to uninstall any services that don’t need to be migrated, and then install fresh what you need after the update. Take it slow and feel free to communicate with us every step of the way.
