So, I have a full node + Electrs on a VM. Have anyone successfully upgraded? Is the process identical?
Tks a lot, I am just afraid to break something and have to start from scratch again.
Upgrading to StartOS 0401 should not be a big deal in a VM.
But flashing would be the most stable and recommended way of doing the process.
Here are detailed intructions on the whole process:
You will just have to slightly adapt them to your VM instead of using a USB thumbdrive.
I worked fine and better than I expected. I really enjoy that now we can connect directly using the ports.
Congratulations for the S9 guys for the UI and exposing the services using the ports, I will donate some sats.
