Upgrade to StartOS 0.4.0 and Lightning Terminal
LITD won’t start up again after upgrading the service to the latest version and then performing the StartOS 0.4.0 upgrade from 0.3.5.1:
2026-07-25T23:15:52+01:00  2026-07-25 22:15:52.018 [INF] LITD: LiT version: 0.17.0-alpha commit=v0.17.0-alpha commit_hash=08934deeefe306d99e402c6c683bac3171fff88f
2026-07-25T23:15:52+01:00  error starting main proxy HTTP server: unable to listen on 0.0.0.0:8443: listen tcp 0.0.0.0:8443: bind: address already in use
2026-07-25T23:15:52+01:00  2026-07-25 22:15:52.019 [INF] LITD: Listening for http_tls on: 127.0.0.1:8443
2026-07-25T23:15:52+01:00  Error: /bin/litd exited with code 1
2026-07-25T23:15:52+01:00   at ChildProcess.<anonymous> (/usr/lib/startos/package/index.js:4521:39)
2026-07-25T23:15:52+01:00   at ChildProcess.emit (node:events:524:28)
2026-07-25T23:15:52+01:00   at ChildProcess._handle.onexit (node:internal/child_process:293:12)
2026-07-25T23:15:52+01:00  Health Check lit failed: lit daemon crashed
I’ve tried rebuilding the Lightning Terminal service, but it didn’t seem to help - same error. Any ideas?
Thanks
Billy
Give me a few hours and I’ll look into it. You might not need LiT on StartOS v040 though, since connection options of LND are greatly expanded.
This might be be an OK answer IF (and I don’t know if this is true or not) LiT is not in control of any funds (or assets, but I don’t have any non-bitcoin trash :smile: ). I’m pretty sure I haven’t messed around with Pool either. Thx, will let you ruminate on it.
LiT has nothing to do with holding your funds. It’s primarily a means of connecting to LND in StartOS v0351, and pretty redundant in v040
OK, looks like I’ve been able to fix it. Check for updates.
same issue here too lit daemon crashed
The latest update of the LiT service did fix it for me
