Upgraded to 0.4 now my Start9 is bricked
Had my Start9 for a couple of years and has worked fine, until I’ve upgraded to 0.4 then everything stopped working…
I upgraded to 0.4, updated the apps as instructed. Then tried to test my connections to my nodes and my TOR was no longer working (even after installing the TOR app and trying 50002 on the connection instead of 50001:t via Electrum. As that wasn’t work I went to reboot and selected “shutdown” via the system settings.
I then started my start9 again which would only load into the boot and ended up in a boot loop with errors “Not activating mandatory access control as /sbin/tomyo-init does not exist.”
I also tried to login via this console and it said invalid login details even though I was entering the correct login details for my Start9 server.
I then read on here that re-flashing fixes the issue so I’ve created a boot drive with the ISO on via BalenaEtcher and plugged that into the Start9, that then presented me with a page to configure the Start9 again, select country and select the boot drive and data drive which I selected. I then went to confirm on that and received an error which I couldn’t capture as it appeared and disappeared too quickly but it was relating to being connected to a VPN.
I then restarted again and now the start9 wont even connect to my monitor and if I try and access it through start.local and enter my RPC details it says unauthorised access.
There is no documentation on 0.4, or guides so I would appreciate some help on getting my start9 back up and running. If someone could please provide detailed instructions on how to fix this issue.
What server hardware are you running StartOS on?
Start9 Server Pure 4TB
