Use Jellfin in Nvidia Shield TV Pro (Android TV)
Hey there,
I have installed jellyfin + nextcloud on the start9 server. The Jellyfin server receives its media data from nextcloud. Now I want to access Jellyfin from different devices. This works from the browser and my Android/GrapheneOS device with the Address.local from the local LAN without any problems.
However, if I want to access Jellyfin from the Android TV device with the same local address, I get the error message: “Connection to server not possible, tried the following addresses:…”. Can someone explain to me which configuration is faulty?
Hi there!
Some clients, such as ‘Jellyfin for Roku’ and ‘Swiftfin’ (tvOS), are not configured to use Local DNS. As a result, these clients are unable to resolve private URLs like .local. I’m not sure about Android TV, but based on what you’re saying, it seems to be the case.
This will be addressed in StartOS v.0.3.6 by deprecating mDNS aliases and assigning every interface of every service a unique port on the LAN. This allows for the manual setup of VPN or clearnet connections.
Said that there is a workaround to make it function solely using your IP and port 8096. To achieve this, you need to follow this guide, but instead of exposing the Bitcoin or Electrs port, you need to utilize this configuration to expose port 8096:
cat > /lib/systemd/system/socat.jellyfin.service <<'EOL'
[Unit]
Description=socat Jellyfin forward
Wants=podman.service
After=podman.service
[Service]
Type=simple
Restart=always
RestartSec=3
ExecStartPre=/bin/bash -c "/bin/systemctl set-environment IP=$(ip route | grep default | awk '{print $9}')"
ExecStart=/usr/bin/socat tcp-l:8096,fork,reuseaddr,su=nobody,bind=${IP} tcp:jellyfin.embassy:8096
[Install]
WantedBy=multi-user.target
EOL
So you have two options. Wait for new StartOS or try to hack it yourself.
Hey Homer,
thanks for your feedback. I’ll see if i can get your suggestion implemented.
It worked with the combination of the guide and your changes. Thank you for your help.
I took the following steps:
Login to StartOS over SSH and switch to the root user:
sudo -i
Run the following command to switch to the “chrooted” environment, any system changes made now will be persisted across reboots.
/usr/lib/startos/scripts/chroot-and-upgrade
Install socat
apt install socat -y
expose port 8096
[Unit]
[Service]
Type=simple
Restart=always
RestartSec=3
[Install]
EOL
systemctl enable socat.jellyfin
Now exit the chroot environment. Note: this will reboot StartOS!
exit
LAN - Address
adjective-noun.local:8096 or ip-address:8096
Worked on my LG TV also. Thank you
Hey! Just a heads-up that Jellyfin version 10.9.7 is currently in beta testing and will be available soon. After updating, all your configurations should still work smoothly. Thanks for checking it out!
Hi, I’m considering having a shot at this. I’m not used to using terminal. I’m wondering about what’s pictured just below “expose port 8096”.
Is that output from a command that you have entered?
Hi,
This is a command you need to copy and paste into your terminal. It creates a new systemd service file at /lib/systemd/system/socat.jellyfin.service, which runs socat to forward network traffic from your server’s local IP on port 8096 to the jellyfin.embassy container on the same port. The service is configured to start after Podman, always restart if it fails, and dynamically determine the server’s local IP address before launching socat.
Do these instructions work on start9 0.4.0 beta9?
To answer my own question, yes, yes it does
You dont need to do it. StartOS v0.4.0 has dedicated IP and port for every service. You just need to trust your rootCA on the device you run Jellyfin client.
What’s weird was I was able to run these instructions and then my TCL Roku TV could connect to the Jellyfin instance on my Start9 DIY 0.4.0 beta 9…But i just came back from vacation and now I can’t connect for some reason.
Do you know if there is a way on the Roku to trust the rootCA cert?
As far as I know, Roku doesn’t let you trust Root CAs.
