Use of obfs4proxy in tor to bypass censorship
To bypass censorship in certain parts of the world you can use obfs4 bridges in tor.
Send an email to frontdesk@torproject.org with “private bridge ” in the subject.
They will send you private obfs4 bridges in your country you can use with tor.
Login to StartOS over SSH and switch to the root user:
sudo -i
Run the following command to switch to the “chrooted” environment, any system changes made now will be persisted across reboots.
/usr/lib/startos/scripts/chroot-and-upgrade
Run the follwing command, this will install ‘obfs4proxy’ on your server.
apt install obfs4proxy
Now exit the chroot environment. Note: this will reboot StartOS!
exit
Logon and switch to root user:
sudo -i
Add the following lines to /etc/tor/torrc, use the bridges you received from torproject.org.
UseBridges 1
ClientTransportPlugin obfs4 exec /usr/bin/obfs4proxy
Bridge obfs4 IP ADDRESS:PORT FINGERPRINT cert=CERTIFICATE iat-mode=NUMBER
Now restart tor with the following command:
systemctl restart tor
Tor logs can be viewed with the following command, or use the StartOS UI.
journalctl -b --no-pager /usr/bin/tor
Write a script called ‘postinit.sh’ that adds the extra lines in /etc/tor/torrc
because torrc gets overwritten during restart.
Put the script into “/media/embassy/config/” which will run each time the server starts up.
Restart your server and check if it works.
Do you have any insight into which countries actively censor Tor connections? I’m simply curious about the extent of such censorship efforts. Thank you for sharing this information.
No I don’t, but I think most countries with authoritarian regimes actively censor Tor.
