Hello. The Bitcoin FAQ on the Start9 support page says:
If you want to use bitcoin-cli, you may do so by adding an SSH key onto your Embassy and exec-ing into the bitcoind docker container.
I added an SSH key and can connect via SSH, but I need help with the docker exec command. The link only gives general info about docker and the rationale for it. Taking an educated guess based on docker documentation, I tried the following but got a permission error:
start9@embassy-xxxxxxx:~ $ docker exec bitcoind bitcoin-cli getblockcount
Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get "http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/bitcoind/json": dial unix /var/run/docker.sock: connect: permission denied
(I know that the block height is available as a property of Bitcoin Core in the web UI. I only used it to test a basic command.)
I also got a permission error trying to list all docker containers (docker ps -a). I’d appreciate any help with this, thanks.
