I cant seem to install and make the VSF version work.
I dont want to copy sync files from startOS (on Optiplex) to my macbook pro … I tried 3 times to reinstall from scratch, it just wont let virtual files activation work ,
Anyone ? Thx in advance
Not everything independent developers release for Nextcloud works properly, and not everything that works properly in Nextcloud for some platforms works properly in Docker containers, and then not everything that works properly in Docker container works properly on StartOS.
“just won’t work” could mean anything… but it’s probably not going to work. As an alternative, you could just use your Nextcloud webDAV address as a network drive on macOS, and just edit files directly from the mac on the server.
