I recently downloaded Start9 and I can’t get Wasabi to run. It shows Bitcoin Core dependency as satisfied but when the status only shows “starting” and it won’t start. I looked up the instructions and didn’t find any steps I need to take to get it up and running. Is anyone else having this issue? Any help much appreciated!
Did you try stop and restarting service and/or restarting the server. That is the first most obvious thing to try. If that doesn’t work you try uninstall reinstall. First make sure your Bitcoin Core healthchecks are green and it is synced.
Thanks. I’m not at home now but will try in a couple of days. I did try start and stop Wasabi and Bitcoin core is running fine, all synced. So Wasabi is working well for you? I’m thinking of installing Bitcoin Knots to run Damus for a Bitaxe. Do you know if Wasabi can be run with Knots?
