Webinterface access no longer possible
I can’t access my start9 node anymore since I plugged the
mini computer to a screen and keyboard,
neither from https://swanky-menu.local/ nor from the assigned
IP address.
The web interface always gets stuck with “connecting…” down in the corner.
What is going on?
Your server might be in diagnostic mode.
Try accessing http://start.local If it is in diagnostic mode it will show an error log and options for you to choose.
I can’t reach it from http://start.local
From http://swanky-menu.local I can reach the web interface,
but it gets stuck in the “connect…” process for ever,
as mentioned above.
What’s the matter?
Hi Fatcat!
What do you see on the screen when starting your server? Are there any errors popping up? Can you log in normally from the connected screen? Have you tried reverting your setup without the screen?
When you see a yellow bar at the bottom that says connecting, it means your web interface can’t connect to the server backend. This could be due to a server issue or a connection problem.
Here are some steps to troubleshoot when cant reach your .local address.
