XBT Node and BTC Node in one device?
Hi guys, I’d like to set up a node for XBT.
Been running a StartOS BTC node on an Intel i5 with 16 Gb RAM with great success using Knots and Electrs. I have it set up with two SSDs; one for OS and services, the other for the blockchain.
Would it be possible to install Knots and Fulcrum and then direct it to a third SSD for the XBT chain which is connected to the computer via (powered) USB?
Or do I need a completely separate device?
I’d prefer one machine for everything for many reasons. Power consumption, saving space, saving a little money.
How are you guys doing this? Anyone else using only one machine?
Thanks in advance!
Going with two devices now. Running both in one node will most likely only work with a very large SSD for both chains since StartOS seems to only be able to talk to one external drive.
Yes it is possible, see here:
No need for additional SSD, when you use the pruned Knots node. The chain is anyway the same before August.
As a… “bitcoiner” I am naturally averse to pruned nodes but in this case it actually makes sense… Thanks!
