Yes, but I haven’t gone through all the steps we discussed earlier. I’ll let you know when I succeed or need your help. Thanks Stu
You may need to install and configure Avahi. You can see here for more discussion on this.
Thank you Alvaro. I thought I may have missed this step, but I did not. When I went through it as you advised, I saw that I had System CA Trust Module already installed. But I unloaded that and re-installed it again. After restart, I tried to access ServerOne remotely, but still got the same “Hmm, we’re having trouble finding that site. …”
Yes, still having issues with Firefox to access ServerOne remotely. Tor works, but it does not recognize my CA Root and give me all the warnings that I will die a horrendous death in the swamp forest.
As I mentioned to Alvaro, I went through the steps for Security Devices and re- installed the System CA Trust Module, but Firefox still will not load the ServerOne remotely. At the top of those instructions it says
"Tip
The path to p11-kit-trust.so will be slightly different if your processor’s architecture is not x86_64."
I don’t know if this applies to this computer or not. Here’s what I have:
System:
Kernel: 5.15.0-134-generic x86_64 bits: 64 compiler: gcc v: 11.4.0 Desktop: Cinnamon 6.0.4
tk: GTK 3.24.33 wm: muffin vt: 7 dm: LightDM 1.30.0 Distro: Linux Mint 21.3 Virginia
base: Ubuntu 22.04 jammy
Machine:
Type: Laptop System: Apple product: MacBookPro9,2 v: 1.0 serial: Chassis:
type: 10 v: Mac-6F01561E16C75D06 serial:
Mobo: Apple model: Mac-6F01561E16C75D06 v: MacBookPro9,2 serial:
UEFI: Apple v: 425.0.0.0.0 date: 10/26/2021
Battery:
ID-1: BAT0 charge: 29.6 Wh (54.7%) condition: 54.1/62.9 Wh (86.0%) volts: 11.2 min: 10.9
model: DP bq20z451 type: Li-ion serial: N/A status: Discharging cycles: 1396
CPU:
Info: dual core model: Intel Core i7-3520M bits: 64 type: MT MCP smt: enabled arch: Ivy Bridge
rev: 9 cache: L1: 128 KiB L2: 512 KiB L3: 4 MiB
Speed (MHz): avg: 1197 min/max: 1200/3600 cores: 1: 1197 2: 1197 3: 1197 4: 1197
bogomips: 23148
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
Device-1: Intel 3rd Gen Core processor Graphics vendor: Apple driver: i915 v: kernel ports:
active: LVDS-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: Apple FaceTime HD Camera type: USB driver: uvcvideo bus-ID: 1-1.1:3
chip-ID: 05ac:8509 class-ID: 0e02 serial:
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: modesetting unloaded: fbdev,vesa
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.3x8.3") s-diag: 398mm (15.7")
There’s a lot more of that system stuff, but I didn’t paste it here thinking it’s not needed for this. If you want it, tell me.
I am going through "Configuring Firefox for Tor and I see at the top of the instructions
"Caution
If you cannot connect after following this guide, your Firefox may be installed in a jailed environment, such as an AppImage, Flatpak, or SNAP. Please try an alternate install method that does not isolate Firefox from the regular filesystem."
This Firefox may be a “Flatpak” install. I will continue go through the Config. Firefox for Tor and it that doesn’t work I will unistall Firefox and reinstall without Flatpak.
I am holding off on this until I complete Config Firefox for Tor and, if that doesn’t work, reinstall Firefox without Flatpak. If all of the above is correctly installed and it still doesn’t work, I’ll install and config Avahi. Please advise if you see me on the wrong path to a solution.
A Success: I tried to install in Tor under Security Devices “System CA Trust Module” like I did in Firefox, but Tor said it would not accept that. But in reality, it did and now I’m in Tor remotely without the warnings.
Firefox still not loading Server One remotely.
This is all good, no issue here.
If everything is working in every single conceivable way other than Firefox… then sure… install the non-flatpak and see what happens…
sudo add-apt-repository ppa:mozillateam/ppa && sudo apt update
on Mint you will probably need to do…
echo -e "Package: firefox*\nPin: release o=LP-PPA-mozillateam\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/mozilla
then
sudo apt install firefox
