Hi, why are you guys from start9 make things complicated? Two years ago , last time I tried to connect to wasabi wallet was do easy! Going to “ properties” copy paste p2p and paste in wasabi and that’s it. Now I tried again and even the following chat with AI didn’t help. It’s a real pain in the ass!! Pls can someone describe how to connect to wasabi?
AI: To connect Wasabi Wallet to an Electrs server on Start9, use the Electrum server settings in Wasabi and enter your Start9 Electrs connection details (host and port) with Tor enabled if needed.
Me:That’s no correct at all! Wasabi requires a Bitcoin RPC endpoint and a BitcoinRPC credential String. Where is these to find in the Electrs on Start9?
AI: You’re right—I gave you the wrong connection details. Electrs does not provide a Bitcoin RPC endpoint or Bitcoin RPC credentials. Electrs is an Electrum server; Wasabi’s Bitcoin RPC fields need to point to Bitcoin Core/Knots, not Electrs.
On StartOS, open the Bitcoin Core/Knots service and look under Properties for its RPC Interface details: the RPC endpoint and the RPC username/password. The credential string is those two values joined with a colon: username:password. Don’t use Electrs’ P2P endpoint or Electrum connection details for these fields. A Start9 support discussion likewise points users to Bitcoin Core’s Properties for the RPC credentials, not Electrs.
If you only have Electrs installed, there’s no RPC endpoint or credential string to retrieve from it; you’ll need Bitcoin Core/Knots running on Start9. Wasabi’s settings distinguish the Bitcoin RPC endpoint from its credential string.
Me: Thats outdated information about start 9 . There is no “ properties” section anymore in the new version of StartOs, instead there are “ Interfaces “ . Where is the RPC endpoint and RPC username/ password ?
AI: You’re right—the current StartOS layout uses Interfaces, not Properties.
For Wasabi’s Bitcoin RPC endpoint and credential string, use your Bitcoin Core service (not Electrs):
Open Bitcoin Core → Interfaces. Find the RPC interface. For a Tor connection, use the Bitcoin Core Tor address with :8332 appended; port 8332 is the RPC interface. GitHub
1
Open Bitcoin Core’s service actions and run Generate RPC User Credentials. Choose a username and save the password when it appears—the generated password is shown once. GitHub
Enter the endpoint in Wasabi’s RPC endpoint field, and enter username:password in its credential-string field.
If you only have Electrs installed, you won’t find Bitcoin RPC credentials there; Electrs provides an Electrum interface, not Bitcoin Core’s JSON-RPC interface.
GitHub
Me: Where is the RPC interface? When open interfaces there are 4 options
ZeroMQ transaction API
ZeroMQ Block API
Peer P2P
RPC API
AI:
Choose 4) RPC API. That is Bitcoin Core’s RPC interface. Open it to see the connection details—use the displayed address and port as Wasabi’s endpoint. The username and password are separate: generate or view the RPC credentials in the Bitcoin Core service’s actions/settings, not in the Electrs service. For Wasabi, put them together as username:password in the credential-string field.
Me:
When open RPC API, it says “ wired connection 1” and there are three access types
local type IPv4
local type mDNS
public ( which is deactivated)
Which one of the first two is the right one ?
AI:
For Wasabi running on a computer on the same home network, use Local → IPv4. It gives you an IP address that the computer can connect to directly.
Local → mDNS is also for the local network, but uses a .local hostname; use it only if that name resolves correctly on the computer running Wasabi. IPv4 is the safer first choice if you’re unsure.
Don’t enable Public. If Wasabi is connecting over Tor from outside your home network, use the Tor RPC address shown in the section below these options, not either local address. StartOS’s guide for Wasabi confirms it connects to Bitcoin RPC, not Electrs.
Me:
So I copied and pasted the https: adress ending in :50282 ( tried both mDNS and IPv4 ) and as credential string I put username:password ( that start9 generated ) but in wasabi the connection attempt failed
AI
The likely problem is the **`https://…:50282` address**. That may be the StartOS interface link, not a Bitcoin Core RPC URL that Wasabi can use directly. I shouldn’t have told you to paste it without checking what Wasabi accepts.
For a same-network connection, use the **Local IPv4** access entry, but check whether StartOS shows a separate **connection address/port** for the RPC API. Wasabi needs that RPC endpoint—not the StartOS dashboard/interface page—and the Bitcoin Core RPC credentials. Don’t switch `https` to `http` or change the port by guesswork; that can still fail, and may expose credentials.
Could you share the exact error Wasabi reports (with any IP, hostname, password, or onion address removed) and the endpoint’s **format**—for example, whether StartOS displays a distinct address besides the `https://…:50282` link? That will help tell whether it’s a protocol/endpoint mismatch or an authentication issue.
Me:
With any attempt wasabi shows the same error “ connection attempt failed “
Startos doesn’t show a separate connection adress/ port for the RPC API . There is
Acces: local
Type: IPv4
Certificate authority : root CA
URL: https://…….:50282
That’s it
AI:
Thanks—that detail helps. The StartOS URL you’re seeing is the actual RPC API interface address; don’t add :8332 to that URL. I was wrong to imply StartOS would show a separate endpoint.
A likely cause is your Wasabi version. A connection bug affected older releases; a Start9 community report says it was fixed in Wasabi 2.7.1. Check Wasabi → About and update if you’re running an earlier version.
Then try the Local IPv4 URL exactly as StartOS displays it, including https:// and :50282, with the RPC credential string as username:password. Wasabi’s documented default endpoint is http://127.0.0.1:8332/, but that’s for a node on the same computer—not the StartOS interface URL.
If you’re already on Wasabi 2.7.1 or newer and it still fails, the generic message alone doesn’t identify the cause. The next useful check is Wasabi’s log for the RPC connection error; also confirm Bitcoin Core is running and that the username/password came from Bitcoin Core, not Electrs. Don’t post the password or full endpoint publicly.
Me:
I didn’t add the 8332 , just the url ending in 50282
I downloaded wasabi yesterday so it’s the newest version
I did as you suggested but it still fails
AI
You’re right, and you’ve followed the steps I gave. I shouldn’t keep asking you to retry the same setup.
The key detail is Certificate authority: root CA. The StartOS RPC URL uses HTTPS, so Wasabi’s computer must trust the StartOS root certificate. If it doesn’t, Wasabi may show only “connection attempt failed,” even when the URL and credentials are correct. The StartOS community’s current instructions confirm using the RPC interface URL and username:password; they don’t require adding 8332 to that URL.
Check that the StartOS root CA is installed and trusted on the computer running Wasabi, then retry with the Local IPv4 URL exactly as shown. Also make sure the URL uses an actual IP address if Wasabi has trouble resolving a local hostname; a reported Wasabi connection bug affected hostname-based endpoints.
If the CA is already trusted, the next useful detail is your computer’s operating system and whether the IPv4 URL contains a numeric IP or a hostname. Please don’t share the full URL or RPC credentials.
me:
My browser ( in the same computer as wasabi application) connects to start 9 , meaning It has Trusted root certificate. Is this a different story, having the computer to trust root certificate , in order for wasabi to connect ?
AI:
Yes—it can be different, though if the browser and Wasabi use the same computer-wide certificate store, the browser working makes an untrusted CA less likely.
Browsers can use their own certificate stores or trust settings, and Wasabi may validate the server certificate differently. Also, the browser successfully opening StartOS confirms the certificate for the StartOS web interface is trusted; it doesn’t by itself confirm the RPC connection’s certificate name matches the exact IPv4 URL you entered.
So I’d no longer treat “install the root CA” as the likely fix. The connection could instead be failing because of how Wasabi handles that RPC interface’s HTTPS certificate, or because the RPC credentials/interface aren’t accepted. I can’t determine which from the generic error alone. The best next check is Wasabi’s log for the underlying TLS or authentication error, with credentials and addresses redacted.
