Hello everyone,
I’m having persistent networking issues with a fresh install of StartOS 0.4.0-beta.5 (nonfree ISO) on a Dell OptiPlex 5060 connected via Ethernet to a Calix GigaSpire BLAST u6t (GS5229E) router.
Hardware:
Dell OptiPlex 5060
Calix GigaSpire BLAST u6t router
Ethernet cable: CAT5e 350 MHz 24AWG
Monitor + keyboard attached for local access
What I’ve done:
Completely wiped the SSD and did a fresh flash/install of beta.5 (previously tried beta.3 with identical results).
Router shows perfect internet: public WAN IP, packets flowing, DNS good.
Ethernet lights on OptiPlex: solid green + flashing amber (link is up).
BIOS: Integrated NIC enabled, FastBoot set to “thorough”
Tried static DHCP reservation on the Calix.
Lowered router firewall to medium (then back to high) — no change.
Symptoms:
During boot: sticks for a while on Job NetworkManager-wait-online.service/start running (___s / no limit) (eventually continues).
**In System → Gateways: For “Wired Connection 1”, shows LAN IP as the one that I reserved for the MAC address of the Optiplex, but WAN IP = “Error” and “port forwarding rules required” with no specific ports listed. **
OS Logs show repeated critical errors:
Network Error: NetworkManager returned no devices. Trying again…
All gateway sync lines show ip_info: None, lan_ip: {}, wan_ip: None, gateway_type: None, only loopback/bridge devices.
Later: Initialized Net Controller but the gateway never populates properly.
**After some time, it recognizes the gateway - error logs show the same thing every 10 minutes**:
0: startos: :net: :gateway: :watch_ip with iface=GatewayId(“eno1”)
at src/net/gateway, rs:941
l: startos: :net: :gateway: :watcher
at src/net/gateway.rs:702
Backtrace omitted. Run with RUST_BACKTRACE=1 environment variable to display it.
Run with RUST_BACKTRACE=full to include source snippets
I used the x86_64 nonfree iso.
Thanks in advance — happy to provide more logs, screenshots, or try any commands from the local UI.
