[Known-Good Hardware Master List] Hardware Capable of Running StartOS
Succesfully installed StartOS 0.3.5.1-nonfree on a chinese MiniPc:
FIREBAT AK2 PLUS MiniPC
Intel N150
16GB RAM
2TB SATA SSD GOLDENFIR (purchased separately - main hd)
512GB NVME SSD (removed during the installation, but it should not be a problem if you set the desired hard drive as the main one - in this case the 2TB SSD - in the BIOS, instead of removing the other hard drive).
The installation was carried entirely from other computer, since the setup would only run if the MiniPC’s only connections were the power supply, and the RJ45 internet connector. Installation does not work with any other peripherical connected. Also, secure boot was disabled in the BIOS.
Successful installed Start9 on Dell Vostro 7620
Got start 9 working on g3 plus gmktec barebones.
Used crucial 16 gig ram and crucial 2tb drive.
Only thing is no sound via the non free iso.
Not a huge issue but no sound for the normal people might be an issue.
AOOSTAR N1 Pro N150 mini PC. I had to use paulscode’s process (on the Start9 community forum) to get it to boot after the installation. All good after that.
Mini PC LIVA Z2 with N4100, 4 GB, eMMC 64 GB, SSD 7 TB.
Installed & successfully runs Start9OS 0.3.5.1 with Knots for 5 weeks to sync.
The sync was rather slow with swappiness=60 (default), a bit better with swappiness=10 but still slower than under Umbrel 1.4.2 the same HW (full 100% sync was finished within 6 days).
Why? No idea !? (Tor?)
After upgrading RAM to 8GB Knots sync became seemingly faster and runs for 3 weeks, but still rather slow at 83% and many time outs (direct LAN cable to router, 600/63 mbps).
Look forward to Start9OS 0.4 with great hope !!!
Thanks to the Start9OS team !
Bosgame Mini PC E3, Intel Twin Lake N150 16GB DDR4 RAM, 512GB NVMe SSD - Upgraded SSD to new 4TB for more storage, then booted from USB stick flashed w/StartOS. Installed StartOS with no issue. Installed Bitcoin Knots and IBD completed in 33.5 hours.
Reporting a successful install of v0.3.5~1 on this hardware combination because I searched and did not see it mentioned so far:
  • Motherboard: ASRock A320M-ITX
  • BIOS: American Megatrends Inc. P5.70 (2019-06-26)
  • CPU: AMD Ryzen 5 3400G (4c/8t, Vega graphics)
  • Memory: 2×16 GB Corsair Vengeance LPX DDR4-3200 (reported/configured 2133 MT/s)
  • Storage: Samsung 980 PRO NVMe 2TB
Running in a little cube SFF case from Silverstone with a 450W SFF power supply.
Added to the list. Thank you!
I setup a Lenovo M70q tiny PC, Intel i3 model with 16GB RAM. Added a Kingston NV3 2TB NVMe PCIe SSD in place of the original drive. Setup StartOS v0.3.5~1 with Bitcoin Knots. Took 19 hours to sync the blockchain on a very modest 100Mbps ISP connection.
Reporting a successful install of 0.3.5~1 on a HP Chromebox G2 with an Intel Celeron CPU 3865U @ 1.80GHz.
I had to install a normal bios on it via mrchromebox but after that I was able to install start9 without issues, everything seems to work fine.
The device is definitely under-powered but it was also only $25 and can be powered by a USB-C PD power supply. Just keep in mind to make a change to the bios to get USB-C PD to work after you flash the bios, more info here.
That’s awesome! For about another $30 you can boost that guy to 16GB of RAM. Should make a fine little, dirt cheap server. Do you know a guide for replacing the BIOS?
Docs for how to replace the BIOS are here: Getting Started | MrChromebox.tech
There are also many other Chromebox devices (such as the Acer Chromebox CXI3) that are based on the same hardware architecture that have i3, i5, and even i7. I’m downloading the blockchain now and both cores are pegged at 100% so having more cores will help with running the bitcoin client. I imagine running electrs will take even longer.
Cool. Thanks! I’ll post that above.
When I said it would make a fine little server, I was not saying it would make a good Bitcoin node, at least not with the current version of StartOS. Maybe with this hack:
I replaced the SSD with a 1TB SATA SSD and it could take an NVMe drive as well. So from a storage perspective I think it will work as a Bitcoin node. The main issue with the G2 with the Celeron is the CPU is slow.
I suspect it’s really going to struggle with the IBD. But do let us know how it goes!
I have successfully installed on PN50-BBR047MD
|Motherboard/CPU|: ASUS PN50 / AMD Ryzen 3 4300U
Graphics|Built-in Radeon Vega 7
32GB DDR4-3200 (2x 16GB HyperX Impact HX432S20IB2/16, SODIMM, CL20).
|2TB Adata XPG SX8200 Pro M.2 NVMe SSD.
(Case: Akasa Newton A50 fanless)
Had to try a few times and change bios settings.
Knots synced and running :slight_smile:
Thank you Start9 team.
That’s an Asus branded mini PC right?
yes, i bought it already repackaged into the fanless case.
it got quite warm (70C+ max range) by the end of pruned download.
With any fanless device especially, you need to provide adequate ventilation for it to cool down effectively.
70ºc is not too crazy, but don’t keep it hidden in a small closet or it might go a lot higher than that.
On the Lenovo M92p, I had significant problem and could not figure out how to keep the machine awake. Did you get that to work? I heard it needs a firmware patch to disable the sleep?
