[Known-Good Hardware Master List] Hardware Capable of Running StartOS
I have not encountered that problem myself, and didn’t patch anything. However, there is a big asterisk there, since it was heavily used when I purchased it (I basically had to cobble it back to life with bailing wire and duct tape), so I cannot say what was done to it by the prior owners. I still have it and can fire it up if you have anything you’d like me to check or some tests to run on it, etc.
BTW, I’ve not tested this (since I don’t have a server that is falling asleep on me), but since Start OS is built on Debian, you might try some of the relevant OS-level commands:
sudo systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target
sudo sed -i 's/^#\?IdleAction=.*/IdleAction=ignore/' /etc/systemd/logind.conf
sudo sed -i 's/^#\?IdleActionSec=.*/IdleActionSec=0/' /etc/systemd/logind.conf
sudo systemctl restart systemd-logind
setterm -blank 0 -powerdown 0 || true
xset -dpms s off || true
Let’s continue the discussion on a new thread (or post over on this thread here, where we talked about the Lenvovo Thinkcentre M92p Small if you prefer).
This isn’t a thread to ask for support. Please create your own threads if you need help with something.
Yep, you were right. It’s been syncing since 2025-09-30 and I gave up today, the blockchain was about 65% synced.
The next device I’m trying is an HP T640 thin client. I was able to install start9 on the HP T640 without any issues other than the wifi card wasn’t working. I tried another wifi card but it still did not work. I’m not sure I’ll look into the wifi card issue since I’ve been told in another thread that wifi will be removed from start9 in the future.
Nevertheless, I think we can add the HP T640 thin client to the list of supported Known good hardware. Might want to add to the Hp Chromebox G2 and just mention that the Celeron CPU is too low spec to run Bitcoin well.
Successfully running a Lenovo yoga 730-15ikb
added 32 GB DDR4 (8 GB on board), 2 TB NVME
BIOs - Secure Boot Disabled and switched to AHCI for SSD detection.
Still in process of syncing knots (+/- 22hrs by my calcs)
Running Hot 80-90 C, hopefully it will cool off when done syncing.
Heading to the donation page!
StartOS 0.3.5.1 works on the Topton X2F N150 (it is a solid fanless firewall mini PC). Note that I installed the bottom fan that it ships with, so I didn’t check the thermals in the fanless configuration. HDMI cannot be connected or it crashes during bootup. I did not test with the non-free ISO, only the normal one.
I’ve been running StartOS on two ZimaBoards without any (hardware-related) issues for years. The recently released ZimaBoard 2, with a PCIe NVMe SSD adapter, provides quite decent performance in a very compact form factor. I can recommend.
MINIX Fanless Mini PC, Intel i3-N350, NEO Z350-0dB, 16GB ram 512GB internal drive, (with a 2TB external)
Note - setup using the nonfree.iso and in headless mode (no monitor or keyboard attached as there were some issues with drivers).
Switching to headless install was seamless
Blockchain synced in ~3 days
Are you sure that’s not the Z350-0db?
Ah nice catch - I misread the description from amazon - will update original message
Just installed Start OS on a
HP ProDesk 4 Mini G1i
512 GB, 16 GB, Intel Core Ultra 7 265T
Added a Samsung 990 Pro
2000 GB, M.2 2280
Stats while Syncing the Bitcoin Blockchain:
GENERAL
Temperature
72.0 °C
MEMORY
Percentage Used
31.6 %
Total
15414.19 MiB
Used
4384.66 MiB
Available
10541.63 MiB
zram Used
481.00 MiB
zram Total
3853.00 MiB
zram Available
3372.00 MiB
CPU
Percentage Used
7.0 %
User Space
5.6 %
Kernel Space
1.4 %
Idle
92.6 %
I/O Wait
0.5 %
DISK
Percentage Used
24.1 %
Capacity
1999.46 GB
Used
481.33 GB
Available
1518.13 GB
wo-we P6 Mini PC AMD Ryzen 5 3550H (4C/8T, up to 3.7GHz) 16GB DDR4 RAM 512GB NVMe SSD, from Amazon for AUD259 (USD169). Comes with Windows 11 Pro. I removed the OEM 512Gb NVMe drive with Windows on it and installed a Patriot P210 SATA 3 2TB Internal Solid State Drive 2.5" SSD- P210S2TB25. There is room made in the base of the case for the installation and the mini PC comes with a SATA adaptor as standard. It has a quiet system fan.
The mini PC is running headless on my home network. Installation of StartOS V0.3.5~1 went smoothly using a Macbook Air laptop and it synced the full blockchain on Bitcoin Knots in 24 hours, so it’s a very speedy little system for cheap money. It replaces my old node which ran Knots on Umbrel/Raspberry 16gb Pi5.
AMD Athlon II X4 640 with 8 GB of RAM, 2TB Lexar NS100 SATA SSD.
I had to help it with IBD by loading the chain from my other node. I’m sure it would have gotten there but probably after a couple months. After sync it’s been running well for a few months now. CPU hovers 60-90% processing transactions. Every now and then Knots complains that the RPC queue is exceeded and DATUM says it can’t update the block, but a minute or two later it catches up. Considering the CPU is nearly 16 years old and is weaker than a Pi 5, this should be considered a marginal setup – but it works.
Successfully working on MSi H410M Pro MB but only after two days of troubleshooting all BIOS settings. In the end I only got it to work by placing the bootloader at /EFI/BOOT/BOOTX64.EFI as described in this post:
hello im looking to get a pc mini for running a bitcoin node, store my photos, whats a good pc mini to start with ? im from mexico so i cant buy the server plus
Scroll up and browse.
Successfully installed and run StartOS 0.3.5.1 on my Lenovo Thinkpad T460 laptop
Replaced the 500GB SSD with a Samsung 870 EVO 2TB SSD
Intel Core i5-6200U CPU @ 2.3GHz
Stock 12GB RAM
USB installed right off the bat
Encountered the following issue upon reboot:
PXE-EG1: Media test failure, check cable
PXE-M0F: Exiting Intel boot agent
Managed to overcome with some BIOS boot option troubleshooting
Knots node up and running!
what about the newer models of minisforum or Geekom? will they work or not
https://www.amazon.es/-/en/GEEKOM-A6-Expandable-Computer-Windows/dp/B0DRP2CPR1/
or this:
MINISFORUM UM680 Slim Mini PC, AMD Ryzen 7 6800H CPU 8C/16T hasta 4,7 GHz, 16 GB DDR5/1TB SSD, Gráficos AMD Radeon 680M, HDMI/USB 4/DP, WiFi, BT, RJ45 2.5G, 4xUSB Port
For certain minisforum servers you might have to do this:
No problems running it on HP ElietDesk 800 G6 mini. Intel i5-10500, 16GB RAM
We should have a thread of hardware that doesn’t work/gives issues.
